Pre-requisites
Autostart
Autostart Configuration
Create a systemd service for automatic startup:
sudo nano /etc/systemd/system/hunter-ros2.service
Add:
[Unit]
Description=Hunter ROS 2 Base Driver
After=network.target
[Service]
Type=simple
User=your_username
ExecStart=/bin/bash -c "source /opt/ros/humble/setup.bash && source ~/hunter_ws/install/setup.bash && ros2 launch hunter_base hunter_base.launch.py"
Restart=on-failure
[Install]
WantedBy=multi-user.target
Enable:
sudo systemctl daemon-reload
sudo systemctl enable hunter-ros2.service
sudo systemctl start hunter-ros2.service
Check status:
sudo systemctl status hunter-ros2.service
Configure the Hunter ROS 2 nodes to start automatically on boot.
MYBOTSHOP Platform Service
If using the MYBOTSHOP configuration, services are managed via systemd:
Start Platform Service:
sudo service hunter-platform start
Check Service Status:
sudo service hunter-webserver status
sudo service hunter-platform status
Service Status Indicators:
  • Green: Service is running correctly
  • Red: Service has failed - restart needed
  • Grey: Service has not started yet
Restart Service:
sudo service hunter-platform restart
Update Startup Job:
After modifying launch files, update the startup job:
ros2 run hunter_bringup startup_installer.py
If the service is green, do not launch hunter_bringup manually as it’s already running in the background.
Manual Launch
Launch the hunter ROS driver manually:
ros2 launch hunter_bringup system.launch.py
Custom systemd Service
Create a custom service file:
Add the following content:
[Unit]
[Service]
Type=simple
User=your_username
Environment="ROS_DOMAIN_ID=0"
ExecStart=/bin/bash -c "source /opt/ros/jazzy/setup.bash && source ~/hunter_ws/install/setup.bash && ros2 launch hunter_base hunter_base.launch.py"
Restart=on-failure
RestartSec=5
[Install]
Enable Service:
Check Status:
View Logs:
journalctl -u hunter-ros2.service -f
CAN Interface Autostart
Create a script to bring up CAN on boot:
sudo nano /etc/network/interfaces.d/can0
Add:
auto can0
iface can0 inet manual
    pre-up /sbin/ip link set can0 type can bitrate 500000
    up /sbin/ip link set can0 up
    down /sbin/ip link set can0 down
Webserver
Web Interface
ROS 2 Web Bridge:
sudo apt install ros-humble-rosbridge-server
ros2 launch rosbridge_server rosbridge_websocket_launch.xml
This enables WebSocket communication with ROS 2 topics and services.
Foxglove Studio:
sudo apt install ros-humble-foxglove-bridge
ros2 launch foxglove_bridge foxglove_bridge_launch.xml
Connect using Foxglove Studio for visualization and debugging.
Web Interface
If the Hunter is configured with an onboard computer, a web interface may be available.
Accessing the Web Interface:
  1. Connect to the robot’s network
  2. Open a web browser
  3. Navigate to http://192.168.131.1:9000/
Login Credentials:
  • Username: admin
  • Password: mybotshop
_images/web_login.png
Web Login Interface
Dashboard
The dashboard provides system overview:
  • View IP Address of the HUNTER
  • View System load and status
_images/web_dashboard.png
Web Dashboard
System Monitoring
Monitor system resources in real-time:
  • CPU, Memory, and Network usage
  • Temperature monitoring
  • System uptime and OS information
_images/web_system.png
Web System Panel
Console
The console provides robot control features:
  • Enable/Disable HUNTER ROS2 Services
  • Battery status monitoring
  • Web Joystick control
  • Pre-configured action buttons
_images/web_console.png
Web Console
Remote Desktop
Access the on-board NVIDIA computer desktop remotely:
_images/web_remote_desktop.png
Web Remote Desktop
ROS 2 Web Bridge
For web-based ROS 2 interaction, install rosbridge:
sudo apt install ros-jazzy-rosbridge-server
Launch the bridge:
Foxglove Studio
For modern web-based visualization:
  1. Install Foxglove Bridge:
    sudo apt install ros-jazzy-foxglove-bridge
  2. Launch the bridge:
  3. Open Foxglove Studio and connect to your robot.
Teleoperation
Keyboard Teleoperation
ros2 run teleop_twist_keyboard teleop_twist_keyboard
Keyboard Controls:
  • i: Forward
  • k: Stop
  • j: Turn left
  • l: Turn right
  • ,: Backward
Joystick Teleoperation
sudo apt install ros-humble-joy ros-humble-teleop-twist-joy
ros2 launch teleop_twist_joy teleop-launch.py
Custom Velocity Commands
ros2 topic pub /cmd_vel geometry_msgs/msg/Twist "{linear: {x: 0.5}, angular: {z: 0.0}}"
Control the Hunter using keyboard:
ros2 run teleop_twist_keyboard teleop_twist_keyboard \
  --ros-args --remap cmd_vel:=/hunter_0001/cmd_vel
Keyboard Controls:
  • i: Forward
  • k: Stop
  • j: Turn left
  • l: Turn right
  • ,: Backward
  • u: Forward-left curve
  • o: Forward-right curve
Web Joystick
If using the MYBOTSHOP webserver, a web-based joystick is available:
Web console with joystick control
Install joystick packages:
sudo apt install ros-jazzy-joy ros-jazzy-teleop-twist-joy
Launch joystick teleoperation:
RC Transmitter
The Hunter can also be controlled via the optional FS RC transmitter:
  • SWA: Parking mode switch (Up: released, Down: parking)
  • SWB: Control mode selector (Up: command mode, Middle: RC mode)
  • S1: Throttle control (forward/backward)
  • S2: Steering control (left/right)
For PC control via ROS2, set SWB to the bottom 3rd position.
Send velocity commands directly:
ros2 topic pub /hunter_0001/cmd_vel geometry_msgs/msg/Twist \
The Hunter uses Ackermann steering. Angular velocity is converted to steering angle internally. Recommended teleoperation speed: 0.2 m/s for mapping.
Visualization
RViz2 Visualization
Launch RViz2 with Hunter model:
ros2 launch hunter_description display.launch.py
View TF Tree
ros2 run tf2_tools view_frames
RViz2 Visualization
ros2 launch hunter_viz view_robot.launch.py
This displays:
  • Robot URDF model
  • TF frames
  • Coordinate axes
  • Sensor data (if available)
View Robot Model Only
To view just the robot model without running the base driver:
ros2 launch hunter_description display.launch.py use_rviz:=true
Web-Based Visualization
For remote visualization, use the web interface:
Remote desktop access for visualization
Custom RViz Configuration
Save your RViz configuration:
  1. Configure displays as desired
  2. File > Save Config As > my_hunter_config.rviz
Load custom configuration:
rviz2 -d my_hunter_config.rviz
TF Tree
View the transform tree:
This generates a PDF showing the complete TF tree structure.
Foxglove Studio
For modern web-based 3D visualization:
Rigs
Sensor Mounting
The Hunter features aluminum T-slot rails for mounting sensors and equipment.
T-Slot Rail Specifications:
  • Standard aluminum profile
  • Compatible with M5/M6 T-nuts
  • Located on top panel
Power Output:
  • 24V from expansion interfaces
  • Maximum 15A continuous
  • Auto-cutoff on low battery
Weight Distribution
  • Maximum payload: 150 kg (Hunter 2.0) / 50 kg (Hunter SE)
  • Center of gravity should remain low
  • Distribute weight evenly for stability
Sensor Mounting
The Hunter 2.0 features aluminum T-slot rails for mounting sensors and equipment.
  • Standard aluminum T-slot profile
Common Configurations
LiDAR Mount:
  • Mount 2D/3D LiDAR on top center for optimal FOV
  • Ensure clear line of sight (360° for spinning LiDAR)
  • Typical height: 20-30cm above chassis
Camera Mount:
  • Front-facing for navigation
  • Multiple cameras for surround view
  • Consider vibration dampening for sensitive cameras
Compute Box:
  • Mount securely to prevent movement
  • Ensure adequate ventilation
  • Route cables cleanly to prevent interference
Power Considerations
The Hunter provides:
  • 24V power output from expansion interfaces
Plan power budget for all sensors and compute equipment.
Weight Distribution
Manipulation
Robotic Arm Integration
The Hunter 2.0’s payload capacity supports integration with robotic manipulators.
Supported Arms:
  • Lightweight collaborative arms (< 10 kg)
  • Research-grade manipulators
  • Custom end effectors
ROS 2 Integration:
sudo apt install ros-humble-moveit
Configure MoveIt for your specific arm model.
Safety Considerations
  • Implement collision detection
  • Define safe workspace boundaries
  • Emergency stop should halt both base and arm
  • Consider arm weight in payload calculations
Maximum payload: 150 kg (Hunter 2.0) / 50 kg (Hunter SE). Arm integration affects the robot’s center of gravity.
Supported Arms:
Power Requirements
  • Arms typically require 24V or 48V power
  • Use the Hunter’s 24V expansion output for compatible arms
  • Consider external power supply for high-power arms
Communication
Common Interfaces:
  • CAN bus (shared with Hunter)
  • Ethernet
  • USB
  • RS-485
ROS 2 Integration
For arm integration with ROS 2:
sudo apt install ros-jazzy-moveit
Arm integration significantly affects the robot’s center of gravity. Recalculate stability margins after adding a manipulator.
Sensors
Depth Cameras
Supported depth cameras:
  • Intel RealSense D435/D455
  • ZED/ZED2 Stereo Camera
sudo apt install ros-humble-realsense2-camera
ros2 launch realsense2_camera rs_launch.py
Lidars
Supported LiDAR sensors:
  • Velodyne VLP-16
  • Ouster OS1
  • SICK LMS series
  • RPLidar
Connect to Hunter’s 24V expansion interface.
GPS
Supported GPS receivers:
  • u-blox series
  • Emlid Reach
  • Fixposition
Auxiliary Sensors
  • IMU (Xsens, Microstrain, Phidgets)
  • Ultrasonic sensors
  • Encoders
Connect sensors to the expansion ports providing 24V power and CAN communication.
Built-in Sensors
The Hunter 2.0 includes:
  • Wheel Encoders: For odometry calculation
  • Steering Angle Sensor: Magnetic encoder (2500 P/R)
Supported External Sensors
The Hunter’s aluminum T-slot rails and expansion interfaces support various sensors:
LiDAR:
  • Velodyne VLP-16
  • Ouster OS1
  • SICK LMS series
  • RPLidar
Cameras:
  • USB webcams
IMU:
  • Drotek IMU
  • Xsens MTi series
  • Microstrain
  • Phidgets IMU
GPS:
  • u-blox receivers
  • Emlid Reach
  • Fixposition
Ouster LiDAR
The Ouster LiDAR provides a 3D point cloud of the environment.
Launch Ouster:
ros2 launch hunter_lidars ouster.launch.py
Configuration:
  • IP Address: 192.168.131.20
  • Provides 3D point cloud data
The Ouster is turned on by default when using the MYBOTSHOP platform service. Only launch manually when the auto service is turned off.
The Intel RealSense D435 depth camera provides RGB and depth data.
Launch RealSense:
ros2 launch hunter_depth_camera realsense_d435.launch.py
Configuration file:
/opt/mybotshop/src/mybotshop/hunter_depth_camera/launch/realsense_d435i.launch.py
By default the RealSense D435 is off. The launch file is configured to enable continuous depth stream information without lag.
Adding Sensors
Connect sensors to the expansion ports:
  • 24V Power: Available from expansion interface (max 15A continuous)
  • CAN: For CAN-based sensors (500kbps)
  • USB: Via onboard computer (if installed)
Sensor Topics
Common sensor topics:
  • /scan: 2D LiDAR scan
  • /ouster/points: 3D point cloud
  • /camera/color/image_raw: RealSense color image
  • /camera/depth/image_rect_raw: RealSense depth image
  • /imu/data: IMU data
  • /gps/fix: GPS fix
Simulation
Gazebo Simulation
Install Gazebo:
sudo apt install ros-humble-gazebo-ros-pkgs
Launch Simulation:
ros2 launch hunter_gazebo hunter_gazebo.launch.py
The simulation provides the same topics as the real robot:
  • /cmd_vel: Velocity commands
  • /odom: Odometry
  • /tf: Transforms
Isaac Sim
NVIDIA Isaac Sim support is available for advanced simulation scenarios. Refer to the NVIDIA Isaac Sim documentation for setup instructions.
Gazebo Simulation
Simulate the Hunter in Gazebo for development and testing.
Install Gazebo:
sudo apt install ros-jazzy-gazebo-ros-pkgs
Launch Simulation:
This starts Gazebo with a Hunter model and ROS 2 interfaces.
Simulated Topics
  • /odom: Odometry
  • /tf: Transforms
Adding Sensors in Simulation
Modify the URDF/Xacro files to add simulated sensors:
  • LiDAR: Add <gazebo> plugin for ray sensor
  • Camera: Add camera plugin
  • IMU: Add IMU plugin
Custom Worlds
Launch with a custom world:
ros2 launch hunter_gazebo hunter_gazebo.launch.py world:=/path/to/world.sdf
Simulation is useful for testing navigation and control algorithms before deploying on the real robot.
Packages
Hunter ROS 2 Packages
ugv_sdk
Low-level SDK for AgileX robots providing CAN communication interface.
hunter_base
Base driver package for Hunter 2.0/SE communication.
hunter_description
URDF models and meshes for Hunter robots.
hunter_msgs
Custom ROS 2 message definitions for Hunter robots.
Key Topics
  • /odom: Odometry data
  • /hunter_status: Robot status
  • /battery_state: Battery status
ugv_sdk
hunter_base
hunter_description
hunter_msgs
Key Topics
Hunter ROS 2 Topics
Topic
/cmd_vel
Velocity commands (geometry_msgs/Twist)
/odom
Odometry data
/hunter_status
Robot status information
/battery_state
Battery status
Key Parameters
  • can_device: CAN interface name (default: “can0”)
  • robot_model: Robot model type (“hunter2” or “hunter_se”)
  • base_frame: Base frame ID (default: “base_link”)
  • odom_frame: Odometry frame ID (default: “odom”)
Debugging
Debugging Commands
List Topics:
ros2 topic list
Check Topic Rate:
ros2 topic hz /odom
Echo Topic Data:
ros2 topic echo /hunter_status
Monitor CAN Traffic:
candump can0
Common Issues
  • Check CAN interface: ip link show can0
  • Verify CAN bitrate: 500000
  • Ensure emergency stop is released
  • Verify parking mode is released (SWA up)
Log Files
ros2 run rqt_console rqt_console
Common Debugging Commands
List Active Topics:
ros2 topic list
Check Topic Rate:
ros2 topic hz /odom
Echo Topic Data:
View Node Info:
ros2 node list
ros2 node info /hunter_base_node
CAN Bus Debugging
Check CAN Interface:
ip link show can0
candump can0
Send Test CAN Message:
cansend can0 123#DEADBEEF
Common Issues
Robot not responding:
  1. Check CAN interface is up: ip link show can0
  2. Verify CAN bitrate: 500000
  3. Check emergency stop is released
  4. Verify parking mode is released (SWA up)
No odometry:
  1. Check wheel encoder connections
  2. Verify hunter_base node is running
  3. Check /odom topic is being published
Steering not working:
  1. Check steering motor connections
  2. Verify steering limits in parameters
  3. Check for error codes on RC display
Log Files
View ROS 2 logs:
Miscellanious
Updating Packages
cd ~/hunter_ws/src/hunter_ros2
git pull
cd ~/hunter_ws
colcon build --symlink-install
CAN Protocol
The Hunter uses CAN bus at 500kbps. Refer to AgileX documentation for protocol details.
Network Configuration
sudo nmcli con mod "Wired connection 1" ipv4.addresses 192.168.1.100/24
sudo nmcli con mod "Wired connection 1" ipv4.method manual
sudo nmcli con up "Wired connection 1"
Time Synchronization
sudo apt install chrony
sudo systemctl enable chrony
sudo systemctl start chrony
Updating Packages
Update Hunter ROS 2 packages:
git pull
cd ~/hunter_ws
CAN Protocol
The Hunter uses CAN bus at 500kbps for communication.
Key CAN IDs:
  • Motion control commands
  • Status feedback
  • Battery information
  • Error codes
Refer to the AgileX CAN protocol documentation for detailed frame definitions.
SDK Development
For custom development, use the ugv_sdk:
#include "ugv_sdk/mobile_robot/hunter_robot.hpp"
HunterRobot robot;
robot.Connect("can0");
robot.SetMotionCommand(0.5, 0.0);  // linear vel, steering angle
Static IP Setup:
For multi-machine setups, synchronize time:
Backup Configuration
Back up your ROS 2 workspace:
tar -czvf hunter_ws_backup.tar.gz ~/hunter_ws
Installation
ROS 2 Humble Installation
Prerequisites:
  • Ubuntu 22.04
  • ROS 2 Humble installed
  • USB-to-CAN adapter
Install ROS 2 Humble:
sudo apt install software-properties-common
sudo add-apt-repository universe
sudo apt update && sudo apt install curl -y
sudo curl -sSL https://raw.githubusercontent.com/ros/rosdistro/master/ros.key -o /usr/share/keyrings/ros-archive-keyring.gpg
echo "deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/ros-archive-keyring.gpg] http://packages.ros.org/ros2/ubuntu $(. /etc/os-release && echo $UBUNTU_CODENAME) main" | sudo tee /etc/apt/sources.list.d/ros2.list > /dev/null
sudo apt update
sudo apt install ros-humble-desktop
Install Hunter ROS 2 Packages:
mkdir -p ~/hunter_ws/src
cd ~/hunter_ws/src
git clone https://github.com/agilexrobotics/ugv_sdk.git
git clone https://github.com/agilexrobotics/hunter_ros2.git -b humble
Install Dependencies:
cd ~/hunter_ws
rosdep install --from-paths src --ignore-src -r -y
Build Workspace:
cd ~/hunter_ws
source install/setup.bash
Add to bashrc:
echo "source ~/hunter_ws/install/setup.bash" >> ~/.bashrc
CAN Interface Setup
sudo ip link set can0 up type can bitrate 500000
ROS 2 Jazzy Installation
Prerequisites:
  • Ubuntu 24.04
  • ROS 2 Jazzy installed
Install ROS 2 Jazzy:
sudo apt update
sudo apt install ros-jazzy-desktop
cd ~/hunter_ws/src
cd ~/hunter_ws
Build Workspace:
cd ~/hunter_ws
Add to bashrc:
CAN Interface Setup
Configure the CAN interface for communication with the Hunter:
To make CAN interface persistent, create a systemd service or add to rc.local.
